PowerGEOPAK SS4 issues
We recently moved from Microstation SS3 / Geopak Suite SS2 to PowerGEOPAK SS4. The PowerGEOPAK version is .878. I have searched the forums to find similar problems and possible answers with no luck.
To date, here are the issues that I have found:
1. Shift / middle button snap pop-ups work up to the bisector snap. Every snap below the bisector snap does not work using this method. This was confirmed at other cadd stations.
2. Export / Import InRoads DTM no longer exists in DTM / Utilities. This is a survey project that I created a tin for and the client requested an InRoads DTM. This conversion existed before in previous version listed above. I figure there is a way to convert this file, but cannot locate it.
3. Help version is old. All help points to Microstation / Geopak SS3.
4. Water / Sewer & Drainage issues with snaps not working when adjusting existing nodes along an existing line. Snaps work when placing nodes initially, but not subsequent node adjustments. This issue existed in previous version of Microstation and Geopak listed above.
Appreciate any help / comments.
Mark
