Dear All,
I just attended webinar regarding OpenRoads: From Concept Through Construction,
As I understand, OPENROADS CONNECT Edition is replacing all 3 road design software which is MXRoad, Inroads Geopak.
Recently my client received select renewal OpenRoads Designer rather than MXROAD, so my question would be as below:
Please ADVISE..
Hi Kugan, 1) Yes Openroads Designer will replace MX Road - Geopak - Inroads 2) You still can use MX Road. MX Road is using Openroads Technologie inside so if you using that it won't be a very big step to Openroads Designer. 3) Good Question no idea, but i think it will be possible to keep using MX Road 4) - 5) They will stop support (service tickets) and developing MX Road so don't think they will force you but you never know!
Dear Jeroen,
Thank you for the information,
It seems the legacy of MXROAD using linemode which we still able to do in MXV8iSS4 would not be available in OpenRoads Designer, it is very disappointing.
Most of our client using this method (linemode) since it's faster and produce drawing in seconds compare in interactive method in OpenRoads,
My question is how stable is the dgn file that we need to work on? If the dgn crash, how to retrieve the design/drawing since no backup file to re-run?
I tested 30km length project and it unable to produce the drawing that I required but I can produce faster in linemode,
I am afraid a lot of people is not going to appreciate the huge changes as they need to learn from beginning. This is because most consultants purchase renewal and new license based on MXROAD legacy tool not on OpenRoads Technology,
Consultants also would worry as on-going project (which they design in MXROAD) is crucial and no time to re-adjust everything to new environment and worried on bugs and crashes.
It's going to be hiccup for 1st quarter of year 2017 where sales (renewal/new license) may drop drastically due to this.
Best Regards,
Kugan (Account Manager & Technical Adviser on MX and ORD)
Unknown said:- Will OpenRoads Designer replace MXRoad? Answer - OpenRoads Designer is the successor to MX, InRoads and Geopak, so yes
after years watching that 3-way (MX, inroads, GEOPACK) support by Bentley I fully appreciate this sooooooo much.
Frank
