Widening the road
Hi!
I want to make widening the road.
I have basis axis and want to make a transition from width1 at station KM1 and end to width2 at station KM2. Start and end shoud be parallel to basis axis. Transition make with two Radiuses with equal tangents.
how to?
br
Marek
Parents Reply
  • I am more a MX user, but I used PowerCivil 8.11.9.878 for the following -  is this what you are trying to achieve? The red arrow points to the lane position W1, and the yellow arrow points to the lane position at W2.
    I used OpenRoads horizontal tools to create the data, and then exported the data to ALG. I am not sure if these tools are available in InRoads v8.11.7.536, but I wanted to check this is the required result. Note the 25m tangent in the middle can be any length you specify.
    If this is not what you want, please show a diagram to explain the situation better.
