Situation - I have multiple random features, each feature contains 1 point. I am trying to run a station base report for all the features (20). The report come backs empty. If I create a dummy random feature but have more then 1 point the report comes back correctly. I am using the FeatureStationOffset report. I have attached the xml with the multiple features selected and one with the dummy feature. Note: I changed the file extensions to .jpg from .xml to post them.
Also, does the station base report pull feature descriptions into the xml file. I am a rookie when it comes to xml but I couldn't find a description in the raw file to put into a formatted report. I am also looking at using the TransverseFeatures report
IR 08.09.02.16
Hi Brian,
You will need to run the Clearance report for random features. Also, the feature's description is in the XML of the clearance report (called "objectDescription"), but I don't think they are included in station base/offset reports.
Kevin
OK. The Clearance report works. Now I am trying to format a report. Once again my low xml skills are a set back. I have the xml stylesheet set up with the correct headings but the raw file is still broken up into offset left and offset right. If anyone can provide a little guidence for me it would be much appreciated. Thanks.
clearence.zip should be .xml
BasicMinimumClearance.zip should be .xsl
My XSL skills are probably not much more than yours, but I think I got this one working. Give it a try.
BrianL_BasicMinimumClearance.xsl Thanks,
