Hello all,
I have a problem - can`t find where in Openroads can change the intervals between the countorus. I used to work with MX and Open Road in one and was possible from the property menu to change the interval between the coutours. Recently have started work with Open Roads and can`t find it anywhere in the menu.
Many thanks in advance,
Petya
The link provided is to a video showing how to do this in InRoads SS3. The question is regarding OpenRoads. How can you do this in OpenRoads?
You will need to look at the element template for this particular feature definition. You can change the intervals there.
This video shows how to do it without changing the feature definition, which is preferable for my situation: https://www.youtube.com/watch?v=W4Bw3bvw2OA. Skip to 4:10 if you want to cut to the chase. Note that you need to have "Override Symbology" in the Properties set to "Yes" before you can change the intervals.
So, you have answered your own question?
Best Regards,
Mark
