ROW lines in Inroads cross sections
Hi everyone.
First of all I want to show Existing ROW boundary in a cross section. I followed
https://www.codot.gov/content/business/designsupport/CADDmanual/CDOTAlignmentDisplayinCross_Section.pdf
However, I couldn't find Export geometry option, My inroads doesn't have a export geometry option. So I took the long way. Created Existing ROW Boundary surface line using 10mm straight line template from ROW boundary alignment. Reason to do that is , because import surface doesn't create single feature from the ROW boundary line. You can imagine all the hassle. Then I included that surface on to my cross section. Now problem is, my style for ROW boundary surface is to use a cell for cross section point. that cell is plotting in 1:1000 scale whereas my cross section is 1:200 or 1:100 sometimes. How can I control the size of the cell to get reduced according to cross section scale. The cell was pre existing. So I really don't know the feature of the cell.
Microstation V8i SS3 08.11.09.459
Inroads V8i SS2 V08.11.07.566
thanks in advance
