Does anyone have a demo of the use of overlay and stripping? If it was as simple as "overlay" and "stripping", we would have two settings in the component properties window. Instead, we have several options.
I know from a provided example that for milling, you want to have the top follow the active surface and the bottom follow the component (as constructed in the template). (Actually, in the example I'm basing this on, it is not a stripping component. I'm not convinced that it matters whether that is toggled on or not.)
I know similarly that for leveling, you want to have the top follow the component and the bottom follow the lowest element (milling, because practically speaking, milling will be the lowest element). (But I misunderstood "Lowest" as I came to this conclusion. Component works just as well for this purpose, in conjunction with the milling component above.)
But there are other options, such as that the top follows the highest, and that the bottom might follow the highest or the surface.
So, partly what I'm confused about is that using any other combination of settings will either do nothing or do something that I can't predict prior to testing. So, I went hunting for the documentation, which I went through the file explorer to find. (The file is at c:\Program Files (x86)\Bentley\PowerGeopak v8i (SELECTseries)\Documentation\geopak_corridormodeling.chm. The article is under Corridor Modeling > Open Create Template > Properties > Component Properties.)
Top Option specifies how the top of the component is defined.
Bottom Option specifies how the bottom of the component is defined. The behavior of these options can be different, depending on the selected Top Option.
What if we want to target a specific component or set of components instead? Or even "Design" as we have that option for point constraints.
In any case, I haven't formed a really solid question around this, but I'm sensing a certain vagueness about the distinction between component depth and surface depth, and the bottom surface of a stripping element seems to be inaccessible to other points in the template.
Does anyone have any advice on how to use all these?
I see Alternate Bottom Surface. This seems to have no function whatsoever. Under what constellation of settings does this do anything? What if I want to use an alternate top surface?
Rolling on 3 years ago since this has been commented on, and no, no comprehensive answer yet. Nothing quite as satisfying as shouting down a well, is there? Well, I like the idea of stripping and overlay components, it would be AWESOME to be able to use them - especially when quantifying materials. The ability to specify a line string that parallels a surface at a set distance (positive OR negative!) and create an area based upon that would be a useful tool to use as long as the constraints were not inscrutable and documentation for their use was decipherable.
Dis you check thoses?
https://www.youtube.com/user/CivilTSG/search?query=overlay
https://www.youtube.com/watch?v=rxLLW7npCr4&t=1385s
