Open Roads - Unable to read the xin file, on computer
 I'm having an issue with one of my work stations, and seems to only happen on this particular workstation.
In Trying to create cross sections I am unable to access the preferences as it does not appear to read the .xin file.
This issue exists even if I use the examples workspace straight out of the box.
Process is:
From Corridor Modeling select
Create Cross sections icon  (r2)
Select Alignment , create cross section icon displays,
Select preferences and no preferences show up, the preferences dialog is completely blank.
The workspace is pointing to Civil_Features_Imperial.xin
Again all other computer do not have this problem, either custom workspace or default from Bentley.
thanks for your help.
Processor Intel, 2.20GHz
RAM, 32GB
Windows 7 Pro , Service Pak 1
64-bit OS
flg
