RE: Power InRoads SS2 [Civil Design Forum]
So here is where I am this morning and a condensed file version of what I see.
I cannot figure out how to print out and compare the settings:
The error occurs with the project defaults.  Both of the xin file I am sending you should be (and seem to work for others correctly in InRoads SS2.  However, they give different results in Power InRoads.  See the attached Geometry Reports.
Note:  My coworker gets the correct geometry regardless of the .xin he chooses in InRoadsSS2.
The error is so small (~1ft:0.99996 ft) that it is difficult to catch unless you have a long alignment.
Let me know if you can see anything…
Thanks so much!
From: caddcop [mailto:bounce-57144964-779f-4c4e-ac49-c13715c2f939@communities.bentley.com]
Sent: Monday, January 30, 2017 3:18 PM
To: CivilDesign@communities.bentley.com
Subject: RE: Power InRoads SS2 [Civil Design Forum]
Description: /cfs-file/__key/communityserver-discussions-components-files/5922/6082.image001.png
Message from Bentley Communities
Description: /cfs-file/__key/communityserver-discussions-components-files/5922/6082.image002.jpg
What about if files are referenced? If they line up, try turning off True Scale and see if a ratio appears on one of the two scale factors. That would indicate some type of working units issue.
We also sometimes have labeled grid coordinates in two files using grid lock with a 50' grid unit and compared how not only do the files align but how the grid coordinates align.
View online
If you encounter issues clicking "View online", check here.
You received this notification because you are subscribed to the forum.  To unsubscribe from only this thread, go here. To unsubscribe from a forum, please see this note.
Flag this post as spam/abuse.
Description: http://communities.bentley.com/notification/read?NotificationId=7794e999-6ec4-4bd7-adfe-906e0d086efd
https://communities.bentley.com/cfs-file/__key/communityserver-mailgateway-mailroom-forumshandler/c6adc12c91a84d77b4fbbe369c88188c/PIR_5F00_ERROR.ALG
PIR_ERROR.ALG
  • In the Project Options, bump the Scale (Precision tab) to its maximum - 0.123456789012.
    Then, look at the Project Defaults again. Mine was set to only 4 decimal places, so either 0.99996 or 1.00004 look like 1.0000.
    I use a calculator to generate this scale factor - 1.000040101019792
    When I enter that as my Default Grid Factor, the ALG reports using Review Horizontal Alignment the same data as ERROR_GEO.TXT.
    Also notice that file (ERROR_GEO.TXT) reports an Input Factor 1.000. But your new output should report something similar to my number.
    Set your Default Grid Factor to 1.0 exactly. Press Apply, Close the dialog box.
    Close and reopen the Review Horizontal Alignment dialog box. You should see two things. There is no Input Factor listed anymore (If its 1, why does it need to report it?) The alignment information now matches the file NO_ERROR_GEO.TXT.
    There can be multiple Project Defaults - make sure all are set to 1.0, unless there is a known reason for it to be otherwise. This kind of setting might come from a Survey Directive. So you may need to check first.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
    Answer Verified By: Debbie Wells
