Geopak cross section offsets with multiple alignments
I have cut cross sections using Alignment A to generate the patterns, cells, and existing ground.  I then wanted to generate proposed cross sections on Alignment A's cross sections using Alignment B (which has its own profile).  I did just that but geopak labels the offsets from Alignment B instead of Alignment A.  I have been told that it should label the offsets from the cross section cell baseline which would be Alignment A but I cannot get it to.  Is there a setting or some other way to get it to label the offsets from A rather than B.  Thanks!
