OpenRoads and schedule simulation
Hi
Please advice me a little bit on corridors and schedule simulations. Meshes produced with OpenRoads corridors are somehow contigous based on how model was prepared. That would not really fit to construction schedule.
What would be the best approach to prepare OpenRoads mesh models for simulation schedules.  For now I think we need to "kill" all civil intelligence of the model and have some luck with splitting mesches with Microstation tools. Looks like very tidious work to be done. and any changes to corridors would requirem rework.
I will appreaciate nay tips from you,
thank you!
Parents Reply
  • Hi Adam, we are currently splitting our corridors up into 100m sections due to the digital engineering requirements for our current project.
    Our current workflow involves creating a new 3D only dgn, referencing the Default-3D models only with no nesting and then merging into master to get meshes and strip all civil data.
    We had a few issues using clip model - the biggest being that it warps the meshes occasionally if your split boundary cuts the mesh along is plane without an overlap. We have since also updated it to save the dgn on every clip as a crash would mean all clipping would have to be redone and functionality to skip the clip if the group exists (vs. quoting the macro).
    I can post up a copy if the updated clip model mvba if you want.
    Mark
    OpenRoads Designer 2023  |  Microstation 2023.1  |  ProjectWise 2023
    Answer Verified By: Adam Wieczorek
