I am trying to do a transition between 2 templates and my problem is that the cut is not done correctly along the transition. Also a small area has its feature definition changed. Also I don't understand why I am editing the transition some points are connected in such way that is doesn't make any sense. The points that define my components are named differently for each template. Thank you for your help.
Hi Andrei,
I believe from previous posts that you are using SS4. I suggest taking a look at these two wiki videos that go over template transitions:
You may need to manually change how the points are mapped between the first and second template. If there are transitions that are generated wrong, then delete that point connection and correct it. Then make sure that you have deleted all the proper constraints. If you upload your data through the Advanced Reply Editor, I can take a look at the transition for you.
Holly
Answer Verified By: Andrei Chiriac
Hi Andrei
I'm facing same kind of issue with transitioning between templates, can you please help me with how managed to solve that issue?
I have change in slope transition, the difference of slope is not distributed throughout the transition length and i am seeing drastic increase over an interval length.
After you map the points, make sure to check what constraints you need and then delete the rest. I find this a good way to control the slopes transitions.
not working for me.. i did removed the constraints.. when i check transition editor through the slider, that shows up right, but i'm unable to see the proper transition in the actual model. Thank you for your response
Do you have a definitive transition length defined? In some instances, you want virtually an instantaneous change from one template to another but in other areas, you want a gap between the last station of one template drop and the start of the next. It is within that cap the the transition occurs.
