I am trying to do a transition between 2 templates and my problem is that the cut is not done correctly along the transition. Also a small area has its feature definition changed. Also I don't understand why I am editing the transition some points are connected in such way that is doesn't make any sense. The points that define my components are named differently for each template. Thank you for your help.
Hi Andrei
I'm facing same kind of issue with transitioning between templates, can you please help me with how managed to solve that issue?
I have change in slope transition, the difference of slope is not distributed throughout the transition length and i am seeing drastic increase over an interval length.
After you map the points, make sure to check what constraints you need and then delete the rest. I find this a good way to control the slopes transitions.
not working for me.. i did removed the constraints.. when i check transition editor through the slider, that shows up right, but i'm unable to see the proper transition in the actual model. Thank you for your response
Do you have a definitive transition length defined? In some instances, you want virtually an instantaneous change from one template to another but in other areas, you want a gap between the last station of one template drop and the start of the next. It is within that cap the the transition occurs.
