I am attempting to place some civil cells in a design file and am running into errors. In the plan view (top down) everything looks correct, but in isometric views, the civil cell is always attached to the surrounding terrain or template drops. the civil cells work in about half of the applications, but the other half show large spikes of surface from the civil cell a hundred or more feet tall (one was about 107,000' tall) above or below the surrounding area.
The same civil cell for all FOUR intersections between proposed sidewalk (in pink) and the existing drives. In this picture, the civil cell works for the intersections moving from bottom right to top left, but they fail to insert properly headed the other direction. (NOTE: there are several other locations throughout the file where both directions inserted completely correctly in both directions. There are also areas where the civil cell spikes extend well below the surrounding terrain.)
My query is in reference to the cause of this error. What are some reasons that only some of these civil cells fail? Is there an issue with the civil cell? The civil cell design library? Could it be a problem with the template drops around the civil cells? Could the issue be with the survey file (Am I attempting to tie to ridiculous terrains in the sky?)?
Any and all help is appreciated; Thank you for your time.
What is the exact product and version you are using? There has been a focus on civil cell issues as new updates are released so it would be good to know the version of the product. One of the first things we suggest for civil cell issues is upgrading to the latest build (currently 08.11.09.878), so you can delete and replace the civil cells to see if it was an issue with how cells were ruled or constructed.
Can you explain how the verticals/profile for the returns were defined in the civil cell? Are you applying a template so an end condition can target a terrain to tie the returns to the sidewalk terrain/corridor? What I notice is how this lower right section appears to have a near vertical face in the edge but it is successfully intercepting the sidewalk. Then for the opposite return in that civil cell, it has an issue with the profile and how that is defined or set to target something (direction in which the reference element is created?). So I didn't know if this was some sort of taper section to slope down to the sidewalk. The profile or an applied end condition slope seems to be the issue so that is definitely where you should focus. Have you tried to rebuild that return element in the civil cell on the side which doesn't solve correctly?
