I have a corridor with different template drops and transitions. All the templates have the same components but the layers have different heights. The problem is that when I go to Component Quantities there is one component that is not included in the report at all. If I go in the 3d view and select the component I can see it's volume under Element Information.
Hi Andrei,
Could you check is the component is "Closed Shape" in the "Component properties" dialog box?
http://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/19045.component-quantities-what-are-my-options-using-openroads
