I am using Power Geopak V8i SS2.
I have section files that have been published into sheet files using the Cross Section Sheet Composition tool. Also, the workspace I am using is a DOT provided workspace, which does not allow me to change levels, I just use the information the DOT provides. However, I noticed one of the linetypes is not displaying in the sheet file the same as it is displaying in the model file. My model (design) file is referenced into the sheet. I reviewed the reference properties and cannot see anywhere an obvious control that may cause this to happen. Attached are two pics of the linetype as it is displayed in the sheet file (first pic) and one of how it is displayed in the model file (second pic). Any suggestions why this would happen ?
MaryB
MaryB,
After trying all the options, nothing is working. The file, per a previous submittal, was displaying the correct linetype, which I have verified. The only change I have made to the file is: I imported the base file (showing correct linetype) into a revised dot file because I was unable to merge to master the new DOT file into my base file, but was able to merge to master my file into the DOT file. It is acting like the linetype definition is not getting read correctly or at all. It does display correctly in my base file, it is just in the sheet where it is referenced into, that it appears as a solid line with no style applied. I also updated the workspaces from the DOT website to ensure it is not a corrupt workspace variable, but no results. I also tried importing the level that is problematic into my sheet from the base file, and Compressed file, but still get no results. When I zoom in close to view the "solid" line in the sheet view, I see a lot of "12"" numbers above the line, see attached pic. I have not ever encountered this before. Any other suggestions are much appreciated.
