OpenRoads Navigator: How do I set the display units for measure tools
A user asked:
This is what we use for working units.
What should we be changing this to before we create the model?
 Lou's Response:
The format of the measure tools in OpenRoads Navigator is based on the Format field in the active file / model where you are initiating the publishing.  You do not have to change all the files, just the one for publishing.  It can be changed even if elements are drawn into the file.   The best way to explain is by a few examples.
If you use MU, you will get measurements in feet or meters.    Example  151.25' or 97.50m.  Note the foot or meter symbol from the Master Unit label field is used.
If it is set to MU:SU, you will get measurements in both units.  Example:  151' 3" or 97m 5cm.
If it is set to MU:SU and you have the MS unit label set to ft and the SU unit label set to si (U.S. Survey inches) then the label will be 151ft. 3si.
There are no user-defined settings in OpenRoads Navigator to control units, except for stationing.
