Not directly. And as you noted, sometimes the Object+slopes option is not adequate.
Here is an easy suggestion that might work for you.
Instead of using the model option use the following:
This will give the result you need which is main object and tie slopes and also show the islands or other objects which lie entirely within the main object. Two possible drawbacks:
I have found the above method to appropriate most of the time but if not then there is a pretty straitforward procedure that might be useful
FYI - I posted an enhancement request to allow the model option to clip at the juntion with existing ground which has not been implemented yet. As always, if enhancements like this are important to you then filing a change request of your own is very important.
Robert GarrettSenior Product EngineerBentley Systems Inc.
