When importing datas from geordination server. Download process was successfully done. But import process always faced failure. And already reinstalled download Microsoft Visula C++ Redistributable packages. But still not fixed. How it will work?
Hello Andrew,
Thank you posting your question on Bentley Forum.
Could you please check the following .dll file which should avail on your system, Path of my system(on windows10) as shown below. In addition to this, please refer the below link for your reference.
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki/31515.failure-message-while-importing-data-from-geocoordination-services
Purva Lakde
I am having a similar issue. The data will download and I can see it on my local drive but I get the following error on import:
"Unable to open file: C:\Users\JAMES~1.TAL\AppData\Local\Temp\1\Bentley\ConceptStationApp\.RealityData\imagery\LC80150332016104LGN00_B8_24E5D84318EE81DA656DCA22D112719E\multiband.xch"
I have checked and the files are there, I am able to open the .xch file in notepad and read it. I have checked my .DLL files, I have both vcamp.dll files and my C++ redistributable packages are as follows:
I'm running version 10.00.05.99 of ConceptStation and I am unable to set the imagery quality to medium or low. It is defaulted at High and there is no down arrow next to it to change it.
Any help would be appreciated.
Thanks!!!
