I created a new field book and imported a text file with survey points. after importing and cleaning the linework and points i noticed that any curves that were drawn have a vertical curve/spline forced into them.
instead of holding the elevations of the points in the feature, the curve dips above and below where it is supposed to be. (see picture below)
it is supposed to be a curved top back of curb feature line. is there a setting in microstation that will stop this from happening?
CURRENTLY USING "cadd Power GEOPAK V8i (SS4) with openroads.
thanks,
Adam
Thanks for the replies. At least I won't spin my wheels looking too hard anymore. I was fiddling around with the CIVIL_SURVEY_SPLINE_TYPE variable (between value 1 and 2) which helped in some areas, but not in all cases.
What a crappy way of interpolating.
