I am trying to create a terrain model from an existing tin. I'm using the "Create from File" tool, selecting my .tin, but it gives me an Import Failed error when I click import. The strange thing is I tried created the same terrain from the same .tin file in a different workspace, and it worked perfectly. I've checked the PCF files and the two workspaces match, so I cannot figure out why it isn't working. Is there something behind the scenes that could be causing the import to fail? I do not have much experience working with .tins/terrains, so it may be an easy fix.
Thanks.
From what I understand the two workspaces are the same, just for different projects. I attached both the .tin and .xml files if you don't mind trying it out. Thanks.
Existing_03062017.tin
Existing_03062017.xml
