What is the correct procedure to create and edit and export a Terrain Model?
What are the correct steps to create a terrain model from field book data?
i created the terrain from the field book. deactivated surveying processing rules in order to make the model editable. cleaned up triangles/swapped edges and so on. extracted boundary and added it to terrain model to maintain my current edits. noticed a curb feature was out of place, fixed curb feature, deleted bad points from terrain model. went to add newly updated curb feature into the terrain. and all looked fine.
went to re-activate survey processing rules to allow the model to be updated automatically if points/feature lines are modified. as soon as i did that, i noticed several survey figures get removed from the terrain model (that had never been touched) and the figure that i modified stayed but the bad points from the original location of the line get added back into the model, even though i had deleted them from the model and updated the survey figure.
SO HOW CAN I GET THE SURFACE TO CREATE, MAKE EDITS TO IT, ADJUST THINGS THAT NEED FIXED, AND RE-ACTIVATE PROCESSING RULES SO THAT THE SURFACE IS EXACTLY HOW I INTENDED IT TO BE AND IS ABLE TO BE UPDATED IF SOMETHING IS MOVED?
Adam Ryan
  • this forum audience need to know the exact version of software you are using. please look for "best practise" article to get started.
    Frank
    since 1985: GIS, CAD, Engineering (Civil)  Senior Consultant : [Autodesk Civil 3D , Esri ArcGIS, VertiGIS: in previous days : Bentley MS V4 - V8i, GeoGraphics, Bentley Map V8i, InRoads,  HHK Geograf, IBr DAVID] :  Dev: [C, C++, .NET, Java, SQL, FORTRAN, UML]
    [direct quote by: http://en.wikipedia.org/wiki/Helmut_Schmidt]: "Wer Kritik übel nimmt, hat etwas zu verbergen"
    Wer Grammatik- und/oder Rechtschreibfehler findet, der darf sie behalten :-)
  • Hello Adam. I feel your pain. I don't deactivate the survey rules in my survey base file. Many times I have to add supplemental data to a survey. As you have found "re-activating" survey rules really open a can worms.
    Is the client requesting a single file deliverable? Or do they want a DTM file (.tin)?
    Here is my very abbreviated workflow:
    1. I will create a surface file from the survey field books. Get that model worked out. Resolve crossing break lines, spikes etc.
    2. Once I'm happy with that model, export that surface to TIN.
    3. Re-import the TIN file through the "Create Terrain Model from file" tool. I make sure the TIN file has name that includes the creation date.
    4. That surface is now the "frozen" in time. My survey surface can remain in an open state that allows revisions. If something does come up (and it will) I just repeat the process.
    Our DOT is requiring us to submit a 3d survey file with no survey field books. Having the surface as a TIN file seems to fit into this workflow well.
    Cliff
