Has anyone succeeded in using a Civil Cell in Openroads Designer, which was created in PowerCivil ss4?
I have not. Cannot even resave the dgn which the Civil Cell was created from. Get message of unsupported Civil Data and I can only open it in read only mode.
Upgrade of SS3/SS4 Civil Cells currently is not supported in OpenRoads Designer CONNECT Edition 10.00.00.120. Attempting to open these files will result in a warning that the file contains unsupported civil data, and the file will be opened Read-Only.
Answer Verified By: Nico Roman
Hi Kevin,Is it possible to bring civil cells developed in SS3 into ORD update 2? I just tried to open one and I didn't get any prompt to upgrade.Thanks,Krzysztof
upgrade dgnlib from SS3 to SS4 (open it in SS4), add variable to your ORD configuration _CIF_ALLOW_EXTENDED_UPGRADES =1, open dgnlib with ORD, click yest when prompted to upgrade. Close dgnlib, open dgnlib.
aw
Best,
Adam
OpenRoads Designer 2023 | OpenRail Designer 2023
