Hi
I'm trying to have a look at the New open roads.
We have downloaded and installed Openroads on a few computers. It seems to work fine on most computers.
I keep an error when first opening via the .exe file and thus I can’t set up my workspace or work set and have no feature definitions.
I have uninstalled and reinstalled with no success. Do you perhaps know another way to set up the workspace or a solution to the crashing when opening? I had to uninstall the beta as it was a later version of the one I installed (10.00.00.120). It seemed to be crashing while trying to access ProjectWise.
Is anyone else experiencing similar problems? Or as a workaround knows how to set up the workspace other than from the initial screen when running the .exe?
David
Hi David, We have seen similar reports from users running ProjectWise Explorer version V10.00.01.71, and the issue is resolved if they upgrade to ProjectWise Explorer version V10.00.02.203. Can you give this a try and see if it resolves your issue as well?
(Also note the original versions of the readme file said ProjectWise V10.00.00.20+ were compatible, but V10.00.02.203 was the version tested during certification)
Answer Verified By: David Marx
