Where's the option to import a 2D drawing to a template from elements? It was available in the EAP2?
Thanks in advance.
Christiaan
This is scheduled to be included in a future release. You are correct it was in the EAP2 for testing, but they found some problems that they wanted to fix before including it in a release.
When will this be available again in OpenRoads or OpenRail Desiger? we are running Updt 2 now
We need it :)
Same here
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Hi Kevin, I don't see it in updt 3 yet, please make it available in the next update
//Christiaan
