get median to follow special ditch grade
I have a divided roadway with a median ditch. The median flow line is controlled with a profile. The basic ditch would be a 6:1 down to flow line on each side to the flow line and then a flat bottom connecting the 2 edges. For the ditches I created a component that targets an feature definition vertical. I then created a linear element with the flow line associated with that ditch the active profile. That worked well for the ditches but unable to recreate this for the median...maybe because it has 2 controlled edges. Does anyone have a solution for this? Thanks for your help. brian
  • If you build the two slopes using a fixed value and a fixed width flat bottom, the distance between the two roads and difference in elevation will 100% control the depth and location (x,y) of the ditch. To control a ditch depth, you need some type of variable width or slope segment on one side or the other (or possibly, both).
    What you can do, is after running the corridor with this fixed ditch, is to project one of the flat bottom 3D features to one of the road profiles. This will show you what the ditch does based upon those constraints, compared to your desired profile. Then you can use that information to develop components with controls that allow you to vary the ditch depth.
    You might want to make a null point that the ditch bottom elevation is tied to and add the two variable segments mentioned above and by using the move point tool, move the null point around to see how it modifies the ditch. You will usually learn where you must free any additional constraints yo get the desired results.
    Charles (Chuck) Rheault
    CADD Manager
    • MicroStation user since IGDS, InRoads user since TDP.
    • AutoCAD, Land Desktop and Civil 3D, off and on since 1996
