Hello, I was trying to add toolbars for horizontal and vertical elements, but for some reason i am missing them. If I go to Geometry tab, I cannot see them as well. Does anybody know what the problem is? I have attached the screenshot as well
Answer Verified By: Stanislavas Ivanauskas
I don't seem to have the following options as well. I have attached another screenshot as well.
I actually posted this elsewhere, but I think this might be closer to the mark. Here's what I wrote:
I'm attempting to follow the example in the Bentley Document "InRoads ROW Fundamentals" (available from the LEARN module) in Chapter 6 Importing Geometry From Graphics. I'm also using this in my first project with several alignments. The problem arises at the point of review the alignment and make corrections.
According to the example after reviewing the report and noticing the message "transpose?" you do the following:
"Select Geometry > Horizontal Element > Check Integrity"
And then,
"Select the first linear segment which starts..."
As an aside you should be doing this with InRoads (we use PowerSurvey) Explorer. This is NOT readily apparent in the instructions. Consequently, as an example, "File > Open" might be the MicroStation Main toolbar, OR, it might mean the InRoads Explorer toolbar. Or you can also right-click over the alignment.
In the example where the selections "Horizontal Element" and "Vertical Element" are supposed to appear, I don't see them on my popup (or pulldown), and the words "Check Integrity" are greyed out. After some searching, I found a solution here:
Why is the "Check Integrity" command unavailable? - OpenRoads | OpenSite Blog - OpenRoads | OpenSite - Bentley Communities.
However, even after doing that, I still don't see the selections on my popup (or pulldown) and "Check Integrity" is still greyed out.
So I guess my I-(sort of)-have-the-same-issue is why can I not see the two selections (even after loading them), why is Check Integrity greyed out, and how do I fix that?
Thanks!
mark
