Hand-editing Cross Sections and pushing changes back to Design?
I have a number of manual changes to make to my cross sections. These are isolated, one-off items that are driven by Engineer's opinion than by reproducible programmatic logic. Things like "why don't we just tie to existing ground at that one section" or "we don't need a ditch, but could you show some grading so it will drain right in there".
As small as these items are, I want these changes reflected in my construction limits (proposed surface boundary) and, if possible, in my proposed surface. Is there a way to "push" hand edits back to my design surface?
Also, I need to run end area/volumes for my earthwork computations. Do those run by cross sections, or are they from model to model? Will they calculate along the top of my design, or will it find my components and include/exclude those volumes as appropriate? All the more reason to make sure that my hand-edits can be pushed back to design...
Thank you.
Parents Reply Children
