"Extract Utility From Graphics".
If you have multiple Pipes coming into one location, like Multiple Catch basin's draining to one Manhole, can you combine Multiple nodes created from extract utility into one node that represents the Manhole? then when I add my cell that represents my Manhole, I can adjust the inverts but only have one node. Currently I am stuck with 5 nodes in one place because each pipe end is it's own node.
