I have just upgraded to PowerCivil for Americas V8i V 08.11.05.37 from PowerSurvey XM (as it is no longer supported).
I am in the process of creating a new dataset by importing raw survey data from a Trimble DC file and have noticed that the instrument heights have not come through, so that the instrument height field only displays 0.000
Needless to say, this is rather frustrating as I have to view the raw survey data to obtain the correct height then manually enter this into the Survey Editor. I encountered the same error before in a previous version of PowerSurvey and was assured that this had been corrected for the V8i release.
Chris,
I thought this has been taken care of. I'll check on it.
Derricke
I had someone check and the problem you reported was fixed in PowerCivil V8i.
At the time, the problem was that Trimble changed their codes from one version to the next. Code 02NM from Trimble V10 is an old code (or obsolete code) that was replace by E0NM in the Trimble version V10-70.
We would need your raw file to see what is going on. Please log a help request with GEOPAK and we'll figure it out.
Derricke,
I have emailed through the raw Trimble DC file through to Bentley Support.
The DC file in question is a V10-70 and the instrument height field is indead preceded by the E0NM code, as seen below (underlined and in italics);
00NMSC V10-70 223110-Oct-08 14:15 113121 10NM09089 122211 13TSTime Date 10/10/2008 Time 11:03:38 95FC 100000 78NM11 65KI D5KI 1.000000000000000.000000000000000.00000000000000 D8KI 64KI> 1.00000000000000 49KI1 50KI 81KI1 C8NM2 E4NMVX & S Series 20148 R10.0.58 3 273.942009210302105.6746113989640.000000000000000.00000000000000 C7NM0.000833333333330.000833333333330.003000000000002.00000000000000 69KI 1000 2000.000000000005000.0000000000030.0000000000000ST 11 D2NM1018.0000000000017.00000000000000.14200000000000 69FD 1000 2000.000000000005000.0000000000030.0000000000000ST 11 E0NM 1000 1.683287841687591.000000000000001 70TP 1001 1000 90.0000000000000 ST 11 E1NM 1000 1001 90.000000000000090.0000000000000 77NM1.62217485294619-35.0000000000000.00000000000000 D9F1 1000 1001 96.554060000000090.836370000000090.0000000000000ST 50.003193108120000.000833333333330.00083333333333 E4NMVX & S Series 20148 R10.0.58 3 273.942009210302105.6746113989640.000000000000000.00000000000000 C7NM0.000833333333330.000833333333330.003000000000002.00000000000000
There is obviously still an issue here and I appreciate your's (and Bentley Support's) prompt response to this and look forward to a swift resolution.
Chris.
I've been in touch with support and they are expecting your data. You should here something shortly. If not, please let me know.
