I'm trying to replicate the geometry created in native tools using OpenRoads Designer horizontal geometry tools. The task is to place an arc between straight and another arc. The arc I want to place has back and ahead spiral and must have the same direction as the existing arc. The picture below shows what I try to achieve (left hand side). Usually in such situations there are two possible solutions and I would expect software to allow me to select desired scenario. The problem I encounter is ORD allow me to place the arc only on a right hand side - right part of a picture.
Could you please investigate?
Regards, Krzysztof
The tool doesn't react for "Alt" key. I attached dgn, cheers.
arc between any element and arc.dgn
