Profile Intersection Point not recognizing intersecting element
I would like to know if anyone else is having this issue, or if there is something that can be done about this issue.
I am having some trouble with using Profile Intersection Point.
In this example I have a line crossing two lines. I have created a line between points using the intersection snap between lines 1 and 2 and intersection snap between lines 1 and 3. Lines 2 and 3 have profiles attached.
I opened a profile model of the newly created line and used profile Intersection Point to show the location of lines 2 and 3 and created a profile from these two points. No problem, this works how I would expect.
I tried the same exact thing with another line I will call A, and created a line between points using the intersection of A and 2 and the intersection of A and 3.
I then opened the profile of this new line and went to use profile intersection point again to show lines 2 and 3 on the profile. One point will register but the other keeps saying "Elements Don't Intersect".
How is this possible? How can the same exact operation work and then not? On top of that, isn't it impossible for these lines to not be intersecting? I built the line off the intersection of the elements I am trying to show the Profile Intersection Point of.
I have tried this upwards of 15 times now, its not a matter of snapping to the wrong element, I have tried this in multiple files, have restarted the program, etc.
