I have received MX design data and I need to bring that into InRoads XM. I figure that since both products are Bentley Systems that there would be an add-in for translating the data. I am having a hard time finding one. I did find a 3rd party app that says it is will do this but I'm hoping for a cheaper avenue. Here is the link, http://www.3am-solutions.com/products/dvsp3/dataImport.asp Does anyone know how I might be able to do this if I do not have access to MX to generate a LandXML file? Thanks,
Nick Johnson
Bohannan Huston, Inc.
www.bhinc.com
Hi Nick,
You have to have MX to export your input file into LandXML or GENIO. You can send me a file and I will translate to LandXML or GENIO (up to you). BTW: 3AM-solution (Dynamite VSP) is in fact qool application for VIZ! Last month I made a alignment review of conceptual design - and I did it in Dynamite VSP! I use it a lot - works perfect with IR!
Piotr
Thanks Piotr, I might take you up on that!
Nick,
InRoads also contains a GENIO translator which will import the MX data straight in. It is in the Tools-->Application Add-Ins-->GENIO Translator. It requires a little bit of setup but is effective once you have done that.
