OpenRoads Designer Export to ALG
Is there an option to export alignments back out to ALG? We have a few clients that still require these files to be submitted separately.
  • <?xml version="1.0" encoding="utf-8"?>
    <LandXML xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.landxml.org/schema/LandXML-2.0 http://www.landxml.org/schema/landxml-2.0/LandXML-2.0.xsd" version="2.0" date="2020-02-28" time="07:09:25" xmlns="http://www.landxml.org/schema/LandXML-2.0">
    	<Units>
    		<Metric areaUnit="squareMeter" linearUnit="meter" volumeUnit="cubicMeter" temperatureUnit="celsius" pressureUnit="HPA" />
    	</Units>
    	<Application name="OpenRoads Designer" version="10.07.03.18" manufacturer="Bentley Systems, Inc." manufacturerURL="http://www.bentley.com" />
    	<Alignments>
    		<Alignment name="CL-ACCESS TRACK 1" length="1212.095232650709" state="proposed" staStart="0">
    			<CoordGeom name="CL-ACCESS TRACK 1" state="proposed">
    				<Line length="383.32111458449106">
    					<Start>5768541.6030249894 676267.37340366223 0</Start>
    					<End>5768522.7977166483 676650.23295658536 0</End>
    					<Feature>
    						<Property label="style" value="Alignment\D-GEOM-CL 10m CH" />
    					</Feature>
    				</Line>
    				<Curve crvType="arc" rot="cw" radius="10000" length="2.3531587093295059" chord="2.3531587039002235">
    					<Start>5768522.7977166483 676650.23295658536 0</Start>
    					<Center>5758534.8388398141 676159.64405060036 0</Center>
    					<End>5768522.681996759 676652.58326822286 0</End>
    					<Feature>
    					</Feature>
    				</Curve>
    				<Line length="826.42095935688849">
    					<Start>5768522.68199676 676652.58326822298 0</Start>
    					<End>5768481.9444672568 677477.99956061994 0</End>
    					<Feature>
    					</Feature>
    				</Line>
    			</CoordGeom>
    			<Profile />
    		</Alignment>
    		<Alignment name="CL-ACCESS TRACK 2" length="1048.9245294593354" state="proposed" staStart="0">
    			<CoordGeom name="CL-ACCESS TRACK 2" state="proposed">
    				<Line length="38.377749704525002">
    					<Start>5768481.6284144912 677484.3776339076 0</Start>
    					<End>5768479.7053049905 677522.70716980658 0</End>
    					<Feature>
    					</Feature>
    				</Line>
    				<Curve crvType="arc" rot="ccw" radius="2008.8000000000002" length="264.36306122133806" chord="264.17232918106447">
    					<Start>5768479.7053049915 677522.70716980682 0</Start>
    					<Center>5770485.9816579996 677623.36816205061 0</Center>
    					<End>5768483.8447774975 677786.84706507507 0</End>
    					<Feature>
    					</Feature>
    				</Curve>
    				<Line length="746.1837185334723">
    					<Start>5768483.8447774975 677786.84706507495 0</Start>
    					<End>5768544.5702333702 678530.55571825407 0</End>
    					<Feature>
    					</Feature>
    				</Line>
    			</CoordGeom>
    			<Profile />
    		</Alignment>
    		<Alignment name="CL-ACCESS TRACK 3" length="232.92767198019197" state="proposed" staStart="0">
    			<CoordGeom name="CL-ACCESS TRACK 3" state="proposed">
    				<Line length="97.349995410125487">
    					<Start>5768520.3399535017 678547.51918177318 0</Start>
    					<End>5768528.4409997491 678644.53152457578 0</End>
    					<Feature>
    					</Feature>
    				</Line>
    				<Curve crvType="arc" rot="ccw" radius="3000" length="37.314452181496094" chord="37.314211647415412">
    					<Start>5768528.4409997491 678644.53152457566 0</Start>
    					<Center>5771518.0356800742 678394.88447898591 0</Center>
    					<End>5768531.7773207845 678681.69628413115 0</End>
    					<Feature>
    					</Feature>
    				</Curve>
    				<Line length="61.940462435286285">
    					<Start>5768531.7773207854 678681.69628413115 0</Start>
    					<End>5768537.6990727326 678743.35302537307 0</End>
    					<Feature>
    					</Feature>
    				</Line>
    				<Curve crvType="arc" rot="cw" radius="1500" length="20.976192413853845" chord="20.976021496896482">
    					<Start>5768537.6990727326 678743.35302537307 0</Start>
    					<Center>5767044.5698930938 678886.75892800733 0</Center>
    					<End>5768539.5584212206 678764.24647652498 0</End>
    					<Feature>
    					</Feature>
    				</Curve>
    				<Line length="15.346569539430256">
    					<Start>5768539.5584212197 678764.24647652509 0</Start>
    					<End>5768540.8118517902 678779.54177346348 0</End>
    					<Feature>
    					</Feature>
    				</Line>
    			</CoordGeom>
    			<Profile />
    		</Alignment>
    	</Alignments>
    </LandXML>
    Hi Mark,
    In fact my alignment got vertical too but unfortunately even with 2.0 version its not picking up for some reason.
  • And fortunately, above attachement label the version as 1.0 though I used 2.0 for output
  • Line 2 shows the LandXML version = 2.- Are you absolutely sure there is an Active Profile on the alignment (I just have to check.)?
