Creating user defined coordinate system
Is there a way to create a new coordinate system (for geodetic conversions), as was possible in previous versions of PowerSurvey?
  • Hi Chris,
    the tool Survey>Geometry>Conversions>Geodetic now links into a library of over 4000 supplied projections.
    Go to the tool, click Geographic Coordinate Systems>Select and set the to and from systems.
    Click the button (shown in the image below) to select the system you want. There is a powerful "search" option available to assist in finding the system you want and, once found, it can be added as a "favorite" for easy retrieval for future use.
    If, by chance, the coordiante system you are looking for does not exist amongst the supplied systems, the previous Survey tool can still be accessed via a MDL Load key in. MDL Load Geod.ma
    Hope this helps...
  • Hi Michael,
    Unfortunatley they do not exist amongst the supplied systems but the Geod.ma tool works great (as in previous versions) so that I can add the needed user defined systems.
    Chris.
