I am using SS4, 08.11.09.878
I have been able to plot cross sections from my model and terrain correctly previously. Today I tried it, and everything is on layer "default" and I do not get my pavement/aggregate structure. I went back to my model file, and everything is on Default" there too. I have NOT made any changes to the model since the last time I looked at the model or cut the cross sections. Apparently I have a setting that is off ... thoughts? It almost looks like level overrides is on, but it is not. If I was in SS2, I would say that it looks like my .tin plotted instead of my .dtm.
On another note. I am able to plot pipes perpendicular to the roadway by using "solid by extrusion along". The parallel pipes are not plotting. Thoughts?
Thanks for the help.
I had my design stage set to "Final-mesh". Once I set it back to "final" everything worked fine. Thanks for the help.
