I'm trying to grade a pond adjacent to a road. The drainage guys gave me the pond bottom elevation and I have a 3D Hinge Point. I wanted to simple run a Linear Template along the hinge to locate the bottom along that area. I say that End Conditions have a Target Elevation mode. Once Selected, there is no location to identify the elevation to target. I tried creating the linear template, assuming it would ask for the elevation during placement, but no prompt appeared.
So now I have a linear template created, but its not displaying anything.
The Help file is no help.
To input targeted elevation use Vertical Offset field in your End Condition component properties window:
Best,
Adam
OpenRoads Designer 2022 (10.12) | OpenRail Designer 2022 (10.12)
Answer Verified By: caddcop
MaryB
I guess you can think about it as a vertical offset from zero.
I've written code for dialog boxes in VB and VBA. It would not be too difficult to make the Offset label change to Elevation when Target Elevation is selected.
