Hi all,
I have been trying to use Microstation Connect Constraints with OpenRoads Designer geometry with no apparent issues except having to nudge the geometry (by slightly extending, moving, etc.) to sync the OpenRoads geometry (ie. 3d) with the CAD element when the constraint manipulates it (if that makes sense).
Has anyone found any issues with using Constraints with OpenRoads geometry? Any plans to add a relationship marker for OpenRoads geometry relationships using Constraints? Definitely adds some more power to geometric construction and an alternative to Civil Accudraw (more options which is a good thing).
