Can a milling component be used in a surface template?
I'm trying to apply a surface template for a mill and overlay project at an intersection. When I apply the surface template with milling components, I receive an error that says the template is invalid because there are no depths in the template. Is there another way to achieve the mill and overlay here, such as draping a proposed terrain on existing ground? Then I could create a surface template with my existing depths.
Thank you.
Parents Reply Children
