Hi all,
We are having some issues with Openroads (MX) SS4 creating open meshes (no end face) when clipping corridors. Has this been (or is this something planned to be) fixed in ORD?
Im assuming this is the reason the corridor component reports haven't been able to incorporate clipping to date?
During some testing in Microstation SS4 using the Mesh tools I am seeing similar issues when splitting and trimming meshes so I assume this is a Microstation limitation?
We have been using a macro that automates the close mesh void command but it is slow in large models (2hrs For our large models with 11000 meshes) and sometimes creates problems in flat mesh situations (ie. End conditions). Is there any way to search for open meshes that can be automated via VBA, etc.
Mark
Maybe the ability to convert corridor components to solids may be the solution?
