I would like to use the "Create Terrain from Graphical Filter" tool to create my proposed surfaces from my corridors. My templates don't have unique feature definitions that are solely representing the desired surface. Instead, in many places, I have the same named feature definition assigned to the top AND BOTTOM component points. When using the Create terrain by graphical filter, I would expect ALL the 3d linestrings to be discovered, but ONLY THE TOP to be used in the resultant terrain model. Unfortunately, I'm not seeing this result. The terrain consistently uses some of the features that are LOWER than other features when creating the terrain. Should this be expected? I'm sure I could probably better assign my feature definitions to uniquely classify the top surface, but feel like this extra work shouldn't be necessary. thoughts?..
Answer Verified By: mlemieux
