InRoads ss4 and .xin file
I have an .xin file that I had created and has been in use now for several years for field survey using Trimble TSC3 data collectors. This worked great with InRoads ss2, but now we have upgraded to InRoads ss4. Through the feature definitions within the Civil standards, within the project explorer, I can load and see the .xin file. When I load survey data (csv) into the InRoads explorer, I can see the csv file, however when I view the field book, all of the survey feature codes are shown as error. At this point in time I am not using all of the dgnlib files because they need to be set up for our survey.
For now I need to be able to load and process survey data as was done with ss2.
How do I get ss4 the read the .xin file?
