Hi,I have 6 x .dgndb files under one folder for different variations of a road intersection.Why can I only refresh and view quantities of the first file I created?The other files only show zero values even if I have added rates under Quantities and Costs.If I move the other files to separate folders, then it gives me costs and quantities again.
Hi Natanya, I couldn't reproduce using 10.0.4.45, which version are you using ?
10.0.4.45 will not update the cost if nothing has changed in the concept, and should display the already calculated costs on opening of the file, so if the costs were calculated in a previous opening of the file, opening the file again and clicking the "Refresh" button will do nothing. (But the costs should already be displayed)
Of course, there is an issue if you have "Proposed" elements and the total cost is still $0, which I understand is your issue.
10.0.5.99 offers the option to delete and refresh all the project costs by clicking and holding the "Refresh" button.
Answer Verified By: Natanya Erasmus
