Is anyone else experiencing massive delay in using the Customize Ribbon dialog in ORD? Using it is fine, but actually opening it takes a while.
I am also having a very lengthy wait (5 minutes+) for it to apply menu changes. My version of Microstation CONNECT does it instantly.
Mark
Answer Verified By: Mark Shamoun
I've found an issue where an edited ribbon dgnlib crashes on opening. Eg. if I save ribbon edits in a dgnlib specified in the Workspace GUIDGNLIBLIST and try to reopen it it crashes, while edits saves to Personal.dgnlib are fine.
I suppose we can only write to Personal.dgnlib for ribbon customisation for now I suppose?
