12D IFC import
Hi
Im looking for a way to display 12D mesh elements in my OpenRoads cross sections.
I can import the .IFC file as a reference or as CAD elements and was hoping it would work like a Revit file so that i could see it. I assumed i needed to change some style configuration associated wit the IFC import but when i use the Item Explorer tab my model crashes every time. This could be because there are too many elements....?
My ultimate goal is to use OpeRoads as a medium to display MX models, 12D models, Inroads models and Revit models all in the same cross sections but stuck with the 12D solids.
David Marx
Parents Reply
  • Hi Gert,
    We have used the Revit imodel exporter in Revit quite alot and it works well. Unfortunately there is no Navisworks referencing / import functionality so the best option would be to get a Navisworks IFC export package and use this as the first you use to allow viewing in MX.
    What David is referring to is that MX uses a Microstation "front end" to import and reference the newer exchange formats like IFC, imodel etc.
    Mark
    OpenRoads Designer 2023  |  Microstation 2023.2  |  ProjectWise 2023
