I installed ORD CONNECT Edition version 10.01.00.15 and I uninstalled the 10.00.00120 version and restarted.... But when I open the program it still says that I am running version 10.00.00.120. Is anyone else having a problem installing the 10.01.00.15 version? Thanks!
To clarify, did you install the 10.01.00.15 version before you tried to uninstall the 10.00.00.120 version?
You may try going through the process again but try uninstalling the current version from the 'Change or Remove a Program' option in the Control Panel. Then make sure it removes the program from that list and check to make sure the icons to load the product are removed. Then I would try to go through the installation again for the Update 1 release.
Answer Verified By: Mitchell Wolff
