The left menu for Open Road Conception in visualization is missed.Press "Tap" also can't work.Aad I have reinstall the software also does not work.
Help please,thanks.
This is a known issue. To work around it, you can close the application while in the Visualization mode and restart OpenRoads ConceptStation. The toolbar should be back.
Marie
Thanks,I have try like this,but it is never change,the menu still missed.How shoule I do?
Which version of ConceptStation are you using? Closing are restarting the application works for me using the latest released version 10.00.05.99.
I have uninstall the old version,than install the latest version 10.00.05.99.But the problem is still there.
Dear Marie,
I have found a method to start the Visualization mode.To start the LumentRT which is attach to the Open Road Concepstation individually(I means no in the visualization window of the ORC).It seems a little complicated,but it works.If you have find a better method,please share it with me,thanks for you suggestion and help.
Best regards!
yanzijj09
