The setting for "Automatically Create 3D Elements" is turned on in the linear default settings so that should make the template automatically create the lines that I need.
The image below shows a point on the template that is drawing the line properly.
The next image shows two points, while using the same feature definition in the same template, that are not drawing the lines properly.
I can't figure out why the "Automatically Create 3D Elements" would work for one point but not the other points even when I am using the same feature definition in the same template.
I have a similar question, I am using SS4, Geopak and tried using the Set Feature Definition with the Create 3D Automatically, and on the cross sections none of the lines are generated. Points are displayed and no interface from the template to the terrain is created. Does this feature still work in SS4?
