I am working on an old project that is several years old using GeoPak SS2 version 08.11.07.615. I am having a problem with both annotating HA Points and VA Labeler within the D&C Manager. The last time we stored anything in the gpk was back in 2014 (started project back in 2002). I stored a new Horizontal alignment and tried to annotate the HA Points and the pull down that shows the alignment names is blank. The VA Labeler is doing the same thing. What might be the problem? I've got several other new projects going and they do not have this problem. All this being said, I can't update to the newest versions until TDOT does.
Old Job
Current Job
Have you tried opening the gpk with cogo? see if the chains/profiles are listed. you can check the database and validate it.
go to cogo > file > database validate
https://communities.bentley.com/products/road___site_design/w/road_and_site_design__wiki
See image after validation. Yes, I can see all of my alignments and profiles in cogo. I'm not having this same issue with newer jobs created in V8i. This job was created in Geopak 2000 and then converted to V8i when we upgraded. I have also Cleaned and Compressed the database as well.
ok. select rebuild database. that should update it.
Ok, I'll try that and let you know.
I tried rebuilding the database and it says that it failed because another task has the gpk open. I'm the only one that is in the database right now.
On a side note, I created an input file of all the data in my gpk, created a new one, and imported all the information into the new gpk. It appears that everything is working as it should. Assuming that creating an input file of all the data worked as it should, I should be back up and running.
