Is there a way to minimize the number of PI's a horizontal alignment created from a Linear Template has? Currently it's placing one every 5' or 10' and I can't seem to find where to change the "interval" spacing. Tried changing the Line Stroking spacing of the alignment and the Design Stage without any luck, any ideas will be greatly appreciated.
We're having issues with Geopak crashing when we try to export to native which is why we're trying to minimize the number of PI's in hope that less PI's to process will keep Geopak from crashing. Thank you
Found a way around it, used the LandXML import feature in Geopak-COGO just make sure NOT to change the "type" of the default extension from .txt to .xml when saving your OpenRoads report. Keep it as .txt but add the .xml to the end of your file name instead. Hope this helps...
